Kraut
Went out to start up my 2010 RT this morning. displays came up normally, got the normal "read...select mode switch" etc. Made sure kill button was on run and hit the starter. had a click and displays went dead. Thought "Hmmm, battery." hooked up the battery charger and after about 10 minutes went out to check the charge and the charger indicated green-charged. thought :cus:.
Inserted key, displays up normal, right up to the "select mode switch" etc. The displays went absolute ape :cus:! analog needles swinging full range, warning indicators rapid flashing, then all went black.
Spent the last 30 minutes searching posts trying to find the same situation but no joy. HELP!
Jim
Jim
