jimcrom
Today a friend of mine was installing four inch risers on a 2010 spyder. I took a ride down to watch and kibitz with him. As some of you know, I do not do mechanics (but I did stay at a Holiday Inn Express, once). While the instructions as someone wrote are 95% good, there is always something that can go wrong. They had a rough time getting the left hand grip off. (Mentioned by another, that they had problems with the hand grip rubber welding to the bar and using a screw driver and Windex to try and make the job easier. Then there were issues of trying to find enough slack. I remembered people discussing about zip ties and down inside and the need to remove the tupper ware.
Thank-goodness for the Do It Yourself section and the videos that people took the time to make. It saved a lot of time and problems. I know in some ways it is like preaching to the choir but if you own a spyder or you are going to take on a project, as I have told anyone who has a spyder that there is a lot of very knowledgeable and helpful people, you need to be on Spyderlovers. I have learned so much stuff being here and while I don't make a lot of posts, I spend a lot of time reading and lurking because as someone once said you have two ears and only one mouth and your actions should match listening vs talking.
Either way I am grateful for the people who make up Spyderlovers.
