Slowpoke387
Still not yet. Just got the shocks Thurs. Was planning on tomorrow but its supposed to rain. Looks like Wed now. Cant wait.Any updates? Have you had it installed yet?
The RonBar stiffens up the suspension so the Spyder doesn't roll to the outside in curves. Once it's installed, you have a whole new ride.
I just bought a used Spyder - 2011 RT Limited SE5. It has several "extras", like high brake LED on trunk, CB/Comm system, chrome handlebar cover, cup holder. How would I know if it has sway bar installed? What do I look for?
"I have put the Baja swaybar on both my Spyders (RS and then my F3s). As mods go, it is pretty cheap and probably the best thing to do for ride quality. If you feel your Spyder is a little squirrely in the turns, then go for it. "
eBay says they are not compatible because eBay's vehicle listings lag behind reality. But they will fit. Besides, you don't want to buy it from eBay anyway. Just email me at [email protected] and you'll save a good deal of money.
Thats great, what is the price on swaybar for Spyderlovers members for ST Limited 2013 currently?
Are you having any promo for clearing it since it is quite a old model?
Did can am modify rts so that baja ron bar is no longer needed?
All of the 2013 and later RT's have the same sway bar. Nothing has changed. That goes for all 2013+ Spyder models. The suspension geometry was changed in 2013 giving the Spyder better handling characteristics. Though the sway bar design, orientation and mounting method were changed with the frame upgrade in 2013. The strength and functional effect of the sway bar remained unchanged from the original, pre-2013 models.
What about adding to the 2016 RTS? Will the baja make a difference with it as well?
What you are describing really sounds more like an alignment issue. Have you had a correctly done laser alignment? I can ride one handed and very relaxed for long distances on my F3. It does not dart or wander. Something is up with your bike.
