PaladinLV
Sway bar has NOTHING to do with leaning!!!
That is the physics of centrifigal force - PERIOD!
If anything you would need to lean more because you'll be able to corner FASTER - ergo more force.
AJ
AJ
Still mulling over adding the BJR swaybar to my 2016 F3-T. I asked this question in another thread, but I think that it may have been buried, so I'm repeating it here:
Given the same radius turn, taken at the same speed, under the same circumstances, would a Spyder with the BajaRon sway bar installed require less leaning into the turn by the rider, than a "stock" Spyder without the BajaRon sway bar would (because the Spyder will dip/roll less to the outside)?
If so, would that mean that you could theoretically take the turn at a higher speed with the BajaRon sway bar, if you lean into the turn the same amount as without the swaybar? (I hope that my meaning is clear....)
Thanks!
