NancysToy
Motorbike Professor
Let's not jump to conclusions, folks. There are several possible reasons for these fires, and we will likely never know the cause of this one, or most of the others. If you want to remove your emissions canister, do so, but don't be lulled into ignoring other possible causes. We have seen at least two fuel filters blow off and leak fuel all over, several more that were loose, and had the potential to leak or blow off. We have also seen several early PE GS's with chafed fuel hoses where they pass the front cylinder head. These had the very real potential of failing where they were worn part way through. The other areas of concern need to be looked at, and corrected if there is a problem. A good mechanic checks this kind of stuff at each service interval.
