danielnor123
I have a 2009 can am spyder RSS and I have had overheating issues with the bike. Today I'm going to get the issues fixed, but for those of you who want to know a kind of easy way or cheap way to find out what is wrong with your bike this is what I did. I went to the Can Am Dealer and had them read the codes and nothing else I paid a total of $28.50, then I went on google play and found an app called spyder codes
https://play.google.com/store/apps/details?id=com.SpyderCodes.pgm
I suggest if you are having issues with your spyder simply go to the dealer pay a low cost just to get the codes read, then download the app and it will guide you on what the codes actually mean.
Anyways here are my code faults and issues, now I'm not mechanically inclined so I don't know how to fix the problem but I'm closer I think to getting it fixed, if anyone has any idea how to help me then I'd appreciate it.
Note: I think code P1116 is where I have the most issues because it concerns the bike overheating, but don't know if everyone will agree to that.
[TABLE="width: 616"]
[TR]
[TD="width: 57"][/TD]
[TD="width: 71"][/TD]
[TD="width: 61"][/TD]
[TD="width: 47"][/TD]
[TD="width: 75"][/TD]
[TD="width: 305"][/TD]
[/TR]
[TR]
[TD="width: 57"]p0130
[/TD]
[TD="width: 71"]occurred
[/TD]
[TD="width: 61"]ECM
[/TD]
[TD="width: 47"]1
[/TD]
[TD="width: 75"]1070h55
[/TD]
[TD="width: 305"]02 Sensor circuit no activity detected
[/TD]
[/TR]
[TR]
[TD="width: 57"]p0170
[/TD]
[/TD]
[TD="width: 61"]ECM
[/TD]
[TD="width: 47"]255
[/TD]
[/TD]
[TD="width: 305"]Lambda regulation high limit
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[TD="width: 61"]ECM
[/TD]
[TD="width: 47"]3
[/TD]
[/TD]
[TD="width: 305"]Lambda regulation: temporary adaptation +/- %
[/TD]
[/TR]
[TR]
[TD="width: 57"]p0600
[/TD]
[/TD]
[TD="width: 61"]ECM
[/TD]
[TD="width: 47"]11
[/TD]
[/TD]
[TD="width: 305"]Communication fault with VCM, no response
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[TD="width: 61"]ECM
[/TD]
[TD="width: 47"]1
[/TD]
[/TD]
[TD="width: 305"]Communication fault with Cluster, no response
[/TD]
[/TR]
[TR]
[TD="width: 57"]p2545
[/TD]
[/TD]
[TD="width: 61"]ECM
[/TD]
[TD="width: 47"]5
[/TD]
[/TD]
[TD="width: 305"]VSS Failure
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[TD="width: 61"]ECM
[/TD]
[TD="width: 47"]5
[/TD]
[/TD]
[TD="width: 305"]VSS light on
[/TD]
[/TR]
[TR]
[TD="width: 57"]p0122
[/TD]
[/TD]
[TD="width: 61"]DPS
[/TD]
[TD="width: 47"]N/A
[/TD]
[TD="width: 75"]
[/TD]
[TD="width: 305"]N/A VCM Communication Fault
[/TD]
[/TR]
[TR]
[TD="width: 57"]C0061
[/TD]
[/TD]
[TD="width: 61"]VCM
[/TD]
[TD="width: 47"]1
[/TD]
[TD="width: 75"]
[/TD]
[TD="width: 305"]N/A Lateral Acceleration Sensor Failure
[/TD]
[/TR]
[TR]
[TD="width: 57"]P1116
[/TD]
[/TD]
[TD="width: 61"]ECM
[/TD]
[TD="width: 47"]123
[/TD]
[/TD]
[TD="width: 305"]Engine Overheat
[/TD]
[/TR]
[TR]
[TD="width: 57"]
[/TD]
[TD="width: 71"]
[/TD]
[TD="width: 61"]
[/TD]
[TD="width: 47"]
[/TD]
[TD="width: 75"]
[/TD]
[TD="width: 305"]*codes occurred and are not active
[/TD]
[/TR]
[/TABLE]
LAMDA sensor #1 upstream cat.
Damaged O[SUB]2[/SUB] sensor wires
connector ECM output pins.
Check fuse
Disconnect HO[SUB]2[/SUB]S 1
Measure voltage between harness connector HO[SUB]2[/SUB]S 1-1 & ground
(expected value 11-13 V[SUB]DC[/SUB])
Measure resistance between HO[SUB]2[/SUB]S 1 pin 1 & 3
(expected value=14 to 15 Ω)
Disconnect ECM B Measure resistance between harness connector HO[SUB]2[/SUB]S 1-3 & ground
(expected value >Open)
Measure resistance from harness connector: HO[SUB]2[/SUB]S 1-3 to ECM B-L2
(expected value: <2 Ω)
The following terms were used in the code explanation.
(pinch gesture to expand)
[TD="colspan: 3"]
TERMS USED IN P0130
[/TD]
Lambda regulation low limit.
Fuel supply problem or air supply problem or mechanical issue on admission parts or exhaust leakage.
Verify fuel pressure verify injectors verify air box throttle body intake manifold and exhaust system.
[TD="colspan: 3"]
TERMS USED IN P0170
[/TD]
VSS failure
VSS light on VSS CAN message missing
Check VCM fault
Measure between harness connector (9-VCM-28 for 46 pins or VCM-32 for 38 pins) and ground (expected value: = 11 to 13 volts). Disconnect MI-IL from DLC connector. Measure resistance between 1-DLC-1 and 1-DLC-2 {expected value 50 to 70 Ω). Measure resistance between 1-DLC-1 and (9-VCM-35 for 46 pins or VCM-37 for 38 pins) (expected value: < 2 Ω). Measure resistance between 1-DLC-2 and (9-VCM-14 for 46 pins orVCM-24 for 38 pins) (expected value: < 2 Ω).
[TD="colspan: 3"]
TERMS USED IN P2545
[/TD]
Engine overheat
Damaged coolant circuit or thermostat or low coolant level Check coolant level add if needed
Check radiator and coolant circuit
Disconnect CTS
Measure CTS resistance value (expected value: 2280 to 2736 Ω at 19 to L1°C (66 to 70°F}). Measure resistance from connector: 5-ECM-A11 to 5-CTS-1 (expected value: < 2 Ω). Measure res1stance from connector: 5-ECM-A27 to 5-CTS-2 (expected value: < 2 Ω).
[TD="colspan: 3"]
TERMS USED IN P1116
[/TD]
Lateral acceleration sensor failure.
Defective lateral acceleration sensor Internal offset fault of he sensor.
Measure voltage between harness connector YRS-4 & GND with ignition on
(expected value=12 V[SUB]DC[/SUB]).
Measure voltage between harness connector YRS-1 & GND with ignition on
(expected value=0 V.
(B.U.D.S.)
[TD="colspan: 3"]
TERMS USED IN C0061
[/TD]
First TAS shorted to GND.
Damaged: TAS sensor wires shorted to ground.
Make sure sensor connector is fully inserted
Measure resistance from connector:ECM A-K1 to TAS-A
(expected value <2 Ω)
Measure resistance from connector:ECM A-K3 to TAS-B
Measure resistance from connector:ECM A-E1 to TAS-C
[TD="colspan: 3"]
TERMS USED IN P0122
[/TD]
[TR]
[TD="width: 57"]
code
[TD="width: 71"]
state
[TD="width: 61"]
module
[TD="width: 47"]
count
[TD="width: 75"]
total time
[TD="width: 305"]
description
[/TR]
[TR]
[/TD]
[/TD]
[TD="width: 61"]ECM
[/TD]
[TD="width: 47"]1
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[TD="width: 61"]ECM
[/TD]
[TD="width: 47"]255
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[TD="width: 61"]ECM
[/TD]
[TD="width: 47"]3
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[TD="width: 61"]ECM
[/TD]
[TD="width: 47"]11
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[TD="width: 61"]ECM
[/TD]
[TD="width: 47"]1
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[TD="width: 61"]ECM
[/TD]
[TD="width: 47"]5
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[TD="width: 61"]ECM
[/TD]
[TD="width: 47"]5
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[TD="width: 61"]DPS
[/TD]
[TD="width: 47"]N/A
[/TD]
[TD="width: 75"]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[TD="width: 61"]VCM
[/TD]
[TD="width: 47"]1
[/TD]
[TD="width: 75"]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[TD="width: 61"]ECM
[/TD]
[TD="width: 47"]123
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[TD="width: 57"]
[/TD]
[TD="width: 71"]
[/TD]
[TD="width: 61"]
[/TD]
[TD="width: 47"]
[/TD]
[TD="width: 75"]
[/TD]
[/TD]
[/TR]
[/TABLE]
P0130 module:ECM
Check fuse
ACRONYM | TERM | |
ECM | Engine Control Module | One of the computers that talks to the(vehicle stability system) lives. |
[TD="colspan: 3"]
TERMS USED IN P0130
P0170 module:RS/GS
ACRONYM | TERM |
[TD="colspan: 3"]
TERMS USED IN P0170
P2545 module:RS/GS
Check VCM fault
ACRONYM | TERM | |
DLC | Data Link Connector | The connector in the front that BUDS uses to communicate. |
VCM | Vehicle Control Module | This mechanical/electronic beauty is the heart of the VSS. |
VSS | Vehicle Stability System | The overarching system that helps keep all 3 Spyder wheels on the ground. |
[TD="colspan: 3"]
TERMS USED IN P2545
P1116 module:RS/GS
Disconnect CTS
ACRONYM | TERM | |
CTS | Coolant Temperature Sensor | Provides coolant temp data to the ECM |
[TD="colspan: 3"]
TERMS USED IN P1116
C0061 module:VCM
(B.U.D.S.)
ACRONYM | TERM | |
B.U.D.S. | BRP Universal Diagnostic Software | BRP Dealers have access to this sophisticated software. Some repairs cannot be done without it. |
GND | Electrical Ground | 'This is the Frame Ground. The negative terminal of the battery |
YRS | Yaw Rate Sensor | sensor that senses where in space your Spyder is heading. |
[TD="colspan: 3"]
TERMS USED IN C0061
P0122 module:ECM
ACRONYM | TERM | |
TAS | Throttle Acceleration Sensor | ' Mounted on the handlebars and determines what you you want the Spyder''s engine to do.' |
[TD="colspan: 3"]
TERMS USED IN P0122
