Analog vs digital speedometer delta?
jlg
I have seen a few mph difference between the digital and analog speedo with the digital being a few mph higher. I noticed that at about 63-64 on the digital,the analog showed 60. Any way to reduce them and/or any way to know which is actually the correct speed w/o matching against a car or a mileage marker setup (not yet riding major highways). Anyone else have this issue? I have a 2014 rt-s se6
The digital gauge is more accurate than the analogue gauges. If you unplug your analogue fuel and temp gauge. The digital gauges will be displayed on your spyder information center.
Most people find the digital gas and temp gauges to be more accurate too.
Not adjustable...
most will compare to the gps mph readings. Digital will be more acurate if picking between the two. There are things that can vary the readings so gps is the best. Hard to be exact but the cops radar gun will have it's own reading and it's tough to argue with that one...:roflblack:
