Amazon motorcycle stuff
How long before member bjt hits 500 posts?!
  • Total voters
    15
jeuchler said:
dryheat
I bought "item 140243147662, 10 black Dzuz Fasteners Fairing DUCATI 748 996 998" for $28 + $3 s/h.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=140243147662
or
http://www.kurveygirl.com/shop
but hold off a minute before you order on my account--I'm gonna try to get a chance to pop them in tomorrow, and I'll confirm that they fit well (or at all)! :bigthumbsup:
I bought them too, but haven't had a chance to put them in. Can't beat the price.
-Scotty
dryheat said:
All right... somebody confirm these things will fit yet? ::)
Sorry, dryheat.
I fell off a dumptruck (no, it's not an interesting story) and I've been very slowly hobbling around with a cane.
Soooo, I didn't get the panels trimmed to get the clips on for the right side yet.
Anyhow, here's a pic of the ones I bought (# 140243147662, but kurveygirl.com has lots from which to choose) and you can see that the new black one is slightly shorter than the stock. While the head also has a slightly smaller diameter, the shaft is the same (the teflon washers are identical to stock).
(Stock fastener=silver.)
I'll be replacing the left side as well in my quest for more and more blackness on the Spyder (it'll be like a new moon instead of full moon!) and so I can't use the stock clips, either.
I still think these will be fine (I have one in!) but I can do a photo essay later when I am mobile and can do the job...
Dzuz fasteners part three...
OK, a review and update from last night:
1. The shafts of the dzuz fasteners I bought from kurveygirl..com were the perfect size to fit through the body work snugly. (No problem)
2. The shafts were a tiny bit shorter. After installing and uninstalling five times, I did what I should've done to start: squeeze the spring clips closer with a vise grip so the fasteners "catch" on the clip to start that 1/4 turn. Or, you could buy longer ones!
3. I actually kind of like the black on silver panels look, but I bought them for when I put on black panels. I do think that I can wear off the finish from too much handling, however. I suppose most folks would opt for the silver finish...
4. You definitely need to grind down where the clips go (2 plastic areas, 1 metal) as in Wjillie's real nice set of photos here
All in all, an easy modification that makes access much faster and less likely to lose parts! :thumbup:
(Yes, yes, I know: I'll take photos as soon as I can hobble out to the garage!)
I was forwarded this link, and was surprised of the use of the Dzus bolts for the Spyder.
I have not seen that model of Dzus bolt before, the engagement section is much longer than the Dzus/Panex that I sell. That would effect the "feeling" of getting the Dzus bolts to fit.
It appears you purchased the shorter of the two Dzus bolts that I carry. The shorter have a Working Length of 12mm, but that is a misleading number. The Dzus clip uses 7mm of that working length, so you end up with a grip range of about 5mm. It would seem that the longer Dzus bolt for OEM Plastic, which have a Working Length of 14mm would be a better choice.
If you can photograph the Dzus bolt along side a metal Scale that is in mm, I can estimate the Working Length of these bolts. If not, I will make an effort to buy a single bolt and check it myself. I like to be able to tell people what fits and what does not fit for special applications. If their is anyway I can help out, please let me know.
I am now working on specialized replacement Dzus kits. So if exchanging the Dzus bolts for your Spyder is something the community needs, I will try to develop a kit for you. If anyone is in the Phoenix, AZ area, I would love to check out their Spyder for this kind of kit.
KG of KurveyGirl.com
Dzus part four...
Thanks, KG!
I'll photo the stock fastener with a scale unless somebody beats me to it. For now, here're a couple of quick pics:
I'm down in Tucson, and do get to Phx on occaision... but there are a number of owners in Phx. as well. If one of them doesn't see this and contact you, send me a PM and contact phone/address and I will stop by the next time I'm up there. In the meantime, I will probably figure out an order and get back to you!:D
Thank you for the offer... I had my technical staff (Yes, I don't do this alone) start to take a look at the Dzus bolts for the Spyder. I will get my technical staff to start researching the actual maker, but at first glance it looks like a DFCI part.
It seems some are only doing the conversion is for only 3 bolts on one side. 3 bolts would be the least expensive way to go.
I don't have a special kit for this, but I do sell individual parts for DIY projects. I think at my limited glance and talking it over with my technical staff the Spare Parts: 1 Black OEM Length (14mm) Dzus Bolt with Clip is probably the best choice for his. I sell them as single kits for $5 total (Clip, washers and Bolt). If you exchanged all 6 that would be $30. For Just $2 more you could get prepackaged 10pack of OEM Length Dzus bolts (14mm).
Another nice option would be to get the Button head instead of the "D-Ring" - Spare Parts: 1 Black OEM Length (14mm) Button Head Dzus w/clip. If you wanted to keep the same clean look without the D-Ring. Some people like that option as well.
If someone in the phone area can let me look at their Spyder for a short while with my technical staff, that would be great. My goal is always to get the right parts to people.
KG
