Am I nuts?
I was wondering if you noticed. :D
I would say I am faster on the RT in the twisties and it does just fine on the highway too. I wish it darted out a little better after 70 mph but it get's the job done just fine.
If you're waiting on a bigger motor from BRP I don't think that's going to happen any time soon or at least that's what I've been told by the folks that would know. You guys really need to ride a RT before you decided that the motor is under powered. I would say it will do everything you need it to do when you need it. I ride harder than most and it still puts a grin on my face. :D
Good to know. It makes sense that with a slightly larger wheelbase and more weight in the back the RT is even more stable that the 08/09's Spyders in twisties.
3WD
I think Lamonster has also pointed out that with the fly by wire you can push it more and Nanny is not so obnoxious so you don't back off to keep her from kicking in. The weight is bound to help as well to keep it planted. You could do a little with tire pressures and tow to get more dart to it.:doorag:
