Airbag
rhansen309
I tried to adjust the rear airbag shock and got a "manual" display on the screen. I believe I have read on here before that I need to use a hand pump to put some air in it and see if it holds pressure. If it does then what and if it does not then what??? Any help would be appreciated. Thanks.
There is a "Strut" at the base of the shock, that hooks up to bike. I believe that it is used by the system, to determine what the ride height is, and if adjustments are needed...
Take a peek, and make sure that it hasn't become unhooked... :shocked:
