bmwlarry
I have a 2015 RT Limited with the automatic air level adjustment. My 2015 has always rode a lot harder and bumpier than my 2011 Limited. Dealer checked it over and said all was normal. I checked the air pressure on the rear shrader valve under the seat and it was 12 lbs. We added air up to about 40 lbs. I called the tech and he informed me it does not matter what you manually add, when the bike is started, in gear - the auto system will correct it to where it should be. Last week while on a ride with a friend, also with a limited, we noticed that while the bikes were parked and unloaded, mine was about 3 inches lower that his at the lowest part on the rear fender (I checked the air pressure when I got home and it was sitting in garage - 31 lbs) . I never seem to hear anything when we get on and start it but his makes a noise. I am hard of hearing and it may just be me. Do I have a bad air pump or bag??
