Air pressure for aftermarket (car) tires.
Dan,
You didn't answer my questions. You were talking about this: "If you use non-stock tires, you MUST remember to change the air in your tires every 5,000 miles. Failing to do this will cause rubber gasification to accumulate inside the tires". A person with two doctorial degrees, I though I get a better answer than that.
Mike
I was being a smart a$$. All in fun...all joking...nothing serious at all. FYI rubber gassification is a topic of interest for those engineers involved in tire/energy reclamation types of industries only.
i am sorry if I created confusion. I was just goofing around.
Da!$it Here I thought you were serious. Now my Spyder is sitting in the garage with 4 flat tires and my Nitrogen generator won't work! :banghead::banghead::banghead::roflblack::roflblack:
I haven't laughed this hard in a long time. :roflblack::roflblack::roflblack::yes::yes::banghead: Thanks guys :firstplace:
I have a Michelin HydroEdge on the rear with almost 12,000 miles on it. I run 28 psi in it and recently ran a tire depth gauge across it & found that the tire wear is even across the tire. It had also gone through 1/3 of the usable tread.
Impressive. Thanks.
I also have the Michelin HydroEdge on the rear. Had to replace original at 12,000. The Michelin has 24,000 now & looks like it'll go another 24,000. The HydroEdge is discontinued & has been replaced with the Defender. Just put Kumho Solus KR21's on the front at 36,000 mi.
Sometimes, it is just fun to sit back and watch. :roflblack::roflblack::roflblack::roflblack:
& I put the Michelin Defenders on the front...
Big LOL
Her is the procedure for filling up the tire when your nitrogen gen breaks down.
1. remove anti leak control device from air conduct cylindrical tube on tire.
2. assume horizontal position so you are eye level with cylindrical tube.
3. Moisten upper and lower lips.
4. Completely fill internal air exchange sacs by inhaling until eyes cross.
5. Place moistened lips on cylindrical tube.
6 exhale
7. repeat until tire is inflated. :D
6 exhale
Warm, wet co2 generator.
