AIR HORN
I've installed the Stebel, WoLo and this one:
http://www.ebay.com/itm/111400001326?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
It is slightly more compact, and seems a bit better built. Just as loud though.
I made my own harness and tapped the horn wire for signal. It works great and wakes up the cagers!
I ride in any weather except ice, year round, and it has been perfect.
Is this on your wife's STS? How about a pic from a little farther back? Having only closeups makes it tough to get a good overall view where on the bike it's mounted.
Wolo use.
I have found that ever since I installed the Wolo, I have NEVER had to use the horn (but I have not been near a big city in that time:shocked:). I now use it to warn cattle not to wander onto the road as I am about to pass........mind you, the cattle are in a fenced paddock, but I have to get SOME use out of the Wolo:ohyea:.......(I think the farmer might be getting a bit annoyed though! :lecturef_smilie:
That is on my BMW R1200GS, but I will be putting one on my wife's St-S in the very near future, already on order. I will post photos of the install! :thumbup:
The wiring diagram that has been posted on here for stebel/wolo horns shows hooking up to the battery for power to the horn thru the relay. Has anyone used power from some other place for the horn? Thanks.
Relay/battery
I used a heavy duty relay ( 30 amps) and heavy gauge wire throughout and direct to battery positive. Soldered connections are best ( yes I solder the ring connectors) Striebl is LOUD.
Wimpy horns cause:::::::::::::::::::: Kaos nojoke
Don't. None of the wiring on the Spyder has enough spare capacity to adequately handle an extra load like an air horn and still have a good safety margin.
It actually doesn't... It's BEST to use a relay, and wire it to the battery. nojoke
But it'll work without all of thie "Fuss & Muss"; but I wouldn't want to lean on the horn button for a sustained blast
2015RT Limited I installed a Bad Boy air horn awesome loud sound. rode by a herd of beef cattle and honked the horn the whole herd took off running. at that moment i knew the horn was loud.:p
no need for relay with new 130 motor set up just plug and honk
attachment.php
Wolo BigBoys
I had dealer in Chattanooga install Wolos on both of my 2015 RTs. Then I came home and installed the BRP horns on my John Deere X304 lawn tractor :clap:. Now I'm the horniest guy around :roflblack:
