BertRemington
Suspension failed on the drive home from the selling dealer who assembled the Spyder incorrectly and is apparently NOT the local dealer performing warranty service.
I picked up a new 2021 RT Limited today. On the way home about 100 miles I got on the dash about 5 times a message Suspension failure. ... The dealer where I purchased the bike is a 100 miles away. https://www.spyderlovers.com/forums...1-RT-Limited&p=1624037&viewfull=1#post1624037
15psi is the comfort pressure
I put 15 pounds of air in the air bag and that took care of my suspension failure and the ride is much better. ... I really like it over my 2019. https://www.spyderlovers.com/forums...1-RT-Limited&p=1624184&viewfull=1#post1624184
And then the suspension broke
Yes the dealer is trying. Especially I didn't purchase the bike from them. https://www.spyderlovers.com/forums...ock-leak-oil&p=1635139&viewfull=1#post1635139
When I got it I put 15 lbs in it and it rode great. ... The compressor just doesn't shut off. https://www.spyderlovers.com/forums...ock-leak-oil&p=1635177&viewfull=1#post1635177
I called the dealer today and they haven't found the compressor problem yet. They replaced the shock but have not found why the compressor keeps pumping up the airbag. They have had it 2 1/2 weeks now. https://www.spyderlovers.com/forums...ock-leak-oil&p=1636091&viewfull=1#post1636091
I called the dealer this morning to see what they found out.They said when the shock bolt dropped out it damaged the sensor to the compressor. https://www.spyderlovers.com/forums...ock-leak-oil&p=1636307&viewfull=1#post1636307
The dealer that is doing the work is not the dealer I purchased the Spyder from. They are doing it under warranty. https://www.spyderlovers.com/forums...ock-leak-oil&p=1636460&viewfull=1#post1636460
They said they replaced the censor that regulates the compressor. Same as before they must not have test rode it. It does the same as before. Ride it a short ways and it will have 90 lbs of air in the air bag. https://www.spyderlovers.com/forums...ock-leak-oil&p=1637422&viewfull=1#post1637422
Mine just pumps up 90 lbs in the air bag. I like to keep the air bag about 20 lbs. ... I would like to just have 20 lbs in the air bag. https://www.spyderlovers.com/forums...-is-the-fuse&p=1637427&viewfull=1#post1637427
Based on this history:
(1) 15-20psi is the comfort pressure
(2) the rear suspension including the leveling system is not fully functional
