seagravesg
Hello friends. Please share your wisdom regarding replacing an oem 2020 F3-T failed (hi-beam failed only) headlamp. Somewhat disappointed that the bulb has failed with 10k miles at 3 years age. I drive with hi-beams on to make myself as visible as possible w/no driving lights. Rarely drive after dark. I think they are halogen. Probably will replace both lamps while at it. I do also have fog lights.
>>would you suggest halo replacements as came on the vehicle?
>>suggest replacements with LED's? Are LED's reliable, long life; do they need/come with cooing attachments as well? If so do they fit in headlamp area w/o modification? Prefer the brightness and whiteness of LED's.
>>Is headlamp replacement a challenge? Any directions, tutorials you would suggest?
>>Any other "type" replacement headlamp that I should consider??
ps. with 30+ years riding 2 wheelers, Spyder is forever.
Thanks!
Thanks!
