eddieshep999
I have purchased a Dummy (Fake Alarm Flashing LED)
It’s designed so that when the Spyder is running the Fake alarm LED is off and with the ignition off the Fake alarm flashes
The Alarm has 2 wires Red & Black
The instructions state Connect Red wire to a permanent Live feed
Connect the Black Wire to only get 12v when the engine is running
On my 2018 F3T SE6 I have 3 accessory feeds which are only live when the engine is running
I connected my GPS to one
I connected a Power socket to the 2nd one
And connected Lamonster’s Bright Light for under the front trunk lid to the 3rd one
I connected the Fake alarm LED Red to a permanent Live from the Battery and the Black to a live o the accessory feed from my GPS
I notice Lamonster’s Bright Light is lit although not on full light
I then tried the Black wire to the Power socket Live feed again with the same problem with Lamonster’s Bright Light
The accessory feeds were not being powered as the engine was off
What is causing Lamonster’s Bright Light to receive some power
Any suggestion as to where I should connect The Black wire from the Fake alarm LED to allow it to function as designed to only receive power when the engine is running but not pass power to Lamonster’s Bright Light
Thanks
Thanks
