The fox shocks on my 2012 uses the preload adjustment ring vs the preload cam on older shock or the RS. There is lots written about increasing the preload cam to 4 or 5 to increase handling etc. but I can't find any comments on a similar vein for for my shocks. The manual says there should be 16 7/8 " between the upper and lower shock bolts when the bike has the rider on it. I can have someone do that measurement for me easily enough but say I want the suspension stiffer. How much do I tighten to say go to equivalent of a 4 on the preload cam shocks? Also any idea how these are typically set from the factory? With riding gear I weigh around 230 lbs so I expect even setting it to the suggested setting will be an improvement?
also some suggest jacking the wheel to unload the shock prior to adjusting. Does the same hold true for the fox podium shocks I have? Manual is pitiful. Does the can am shop manual provide this kind of info?
