elkk
Today I adjusted the right rear wheel to move the drive belt away 2mm from the inner flange per the service manual. Adjustment spec is 1mm - 5mm (seems like a wide range) so I decided on 2mm, slightly closer to the right hand flange (the belt had been riding against the flange). All is well with the belt alignment but now I have rear brake squeal/chatter when applying the brakes. I can only assume this noise will stop as the disc brake wears in to the correct alignment with the rotor or am I missing something?
HELP..the rear brake is really loud..chattering / squealing etc etc, even feel vibration thru the bike. Will it wear flat again (and soon)? I eliminated the parking brake and backed off the adjustment so it is not involved, the bike coast freely.
