Adding driving lights
kickinbar
H all..I need some help. Trying to install driving/fog lights I took off my old bike on to my Spyder F3Limited. I would like to use the existing wiring but being electrically challenged I have no idea what wires go where (other than black is ground and red is hot) Is there a wiring diagram for the F3Limited?? Has anyone done this?? I do have an aftermarket push switch that I read about on this forum that looks like it will work. Not plug and play but can just splice the wires.. Thanks in advance for any help!!!
questions
First, where are you trying to mount them? If you are using the stock foglight locations, the wiring is in place and leads up to the right hand blank beside the ignition switch. If not there are customer accessory leads behind the frunk and on the left side of the tank under the access panel. Hope that helps.
