robmorg
I added a Signal Dynamics Wig-Wag Brake Light Modulator for more brake light visibility. I already had the Custom Dynamics LED High Brake Light that also services as rear running light (less bright with the brake off, if you add the "Dual Converter" per the instructions in the link). I installed the modulator module after the high third brake light, so that the high light continues to stay on steady when the brakes are applied. Therefore only the lower original brake lights modulate. When you apply the brakes, the Wig-Wag module flashes the brake lights alternately four times quickly, then together four more times quickly, then flashes them together more slowly until you release the brake pedal. All the while, the top brake light stays on steady. I figured this combination would give me the most visibility.
Here is a short video I took with my phone to show the results. (Sorry it's not better than it is. This is my first attempt at editing and posting a video. I should have zoomed in on the bike more and made the video a tad longer.)
pps:
