Add one more
spydercowboy
Well I just signed my life away and picked up a 2012 RT Limited. Now all my test drives were around town and back roads never going over 50 mph. To get this monster home I had to hit the interstate. It sure took some time but I finally got up to 70 mph and this is where my little problem comes in. I felt like I was weaving all over the place. I don't really think I was but it sure felt like it. Is this normal and does it finally go away? I tired to relaxe and not try to man handle it but it still SEEMED like I was weaving. It probably didn't help that I had a lot of wind to contend with as well. But it's home and now I just have to learn where all the controls are.:yes:
:welcome: and :congrats: on the ryde.
The problem you are experiencing is very typical when you first ride the :spyder2:. It is caused by a tendancy to overcontrol the :ani29:. Grabbing to tight on the handlebars is the main cause. Try to give the handlebars as little input as possible. Act like there is an egg or a bird between your hands and dont crush the bird or break the egg. I also use push pull on the turns.
It take 250-500 miles to get real comfortable. If you are a two wheel rider, expect about 500 miles. If you are new to riding, then the lower end of the spectrum for the learning curve.
Recommend parking lot time, slow curvy roads, then highway and interstate. Each mile will get better as far as the control issues.
Shocks on 4, 18-20 in the fronts and 28 in the back tire are also good places to start on set up.
If you haven't already.
Start here. http://www.spyderlovers.com/forums/...t-for-new-Spyder-owners&highlight=owners+read
Other than that.
Check your front shock adjustment. They may be set to low for your body weight.
Now just how did you know I was fat?:opps: I'll check the front shocks though. Thanks.
I rather figured it must be typical. I am a Harley rider so I'm used to horsing around a lot of weight. The Spyder is really for my wife but she's still too scared to ride it as far as I had to to get home. I think the wind I was dealing with also had a lot to do with making me THINK I needed to control it more. The more I relaxed the better it seemed until the wind would hit me again. Thanks for the suggestions.
One rear wheel pushing two front wheels, Relax your grip and go with the flow, After a while you'll won't even notice it. :thumbup:
Front shocks set to 5, stiffest position, front tires 25 lbs., will cure most of it.
Elkas in front will cure it all.
Have fun, once you get use to it its like driving a sports car.
My dealer (Roberts Sports) called it the "wobbles". I'm a new Ryder (about a month) and have almost 1000 miles. The wind is also a problem for me i try to hold the handlebars like a bird, but whenever there's a big gust, I grab on and the Spyder reacts. I'm trying to relax and grip with my lower body and not my arms. It's getting better since I'm following the suggestions of those who posted to my wind inquiry.
Oh - Hubby increased shock settings to 5 and increased tire pressure. (suggestions from this forum) :thumbup:
:welcome:to our little rodeo! :yes::ohyea:
The twitchiness will go away with time; everybody starts out gripping the bars a bit too tightly, and then trying to over-control the steering.
:shocked: RLEAX... :shocked: :thumbup:
:agree:I came from a Goldwing and felt exactly as you described.2 months now:yes::2thumbs:
Ivor:spyder:
we did too. but you will get "loosen" up and it will go away..we had to adjust the windsheild too, to help with the wind hitting us. We just went from Tennessee to Florida on it... had a blast!! :)
Well I changed the shocks and added air in the tires as suggested and sure enough the wiggy feeling is almost gone. Enough so that I tried the "let's see how fast it will go" thing. Wide open it would only do 100mph. But it is new. I'm guessing as it gets broke in it will loosen up and be able to do a little better than that. But I figured with the speedometer that has it would do much much much more than that.:yikes: Guess someone is an optimist.
Remember this is made in Canada and up there they are in Kilometers and with you being able to set speedometer to KPH 62mph = 100 kph
Congrats on your new ryde
