Scotty, can you tell me what service bulletin this is and maybe a PDF version that I can print out to give to my dealership? I think I have the problem of both the high and low limits set the same. When I first got my 2011 RT Limited the ACS sensor dogbone link was disconnected from the lower connection. This caused the rear suspension to go to into manual mode. Once in manual mode I could lower the suspension setting to a lower level. When this is adjusted I can physically notice the ride height change while riding. After the link was connected I no longer got the orange warning and didn't go into manual mode. However, I recently noticed that no matter what setting I use, soft to hard, that the ride height never changes. If I measure the height at the bottom of the rear mud flap it stays at 16 1/2" no matter what setting is used. This is with someone sitting in the driver seat, engine running, in neutral and parking brake on.
Just saw your edited post above. Do you have a link to the PDF version of 2011-006? Thanks.
