ACS one-way valve
Gunner3773
After seeing several posts about the one-way valve connected to the compressor that fails, I decided to replace mine today. With 36K, I thought I was probably due. My valve was not noticeably leaking, but it sure was corroded. I am glad I ordered the valve and replaced it. I was going to run the valve through my ultrasonic cleaner, but I thought due to the low cost of the the new valve, why bother cleaning it and I probably wouldn't trust it, even cleaned. The valve replacement should be part of BRP's normal maintenance schedule. That moisture in the compressed air really is hard on those valves. Hopefully, my original compressor will carry on!
That's a good idea, it's to bad they would put it in such a place so you could do that easily also!!! Let us know how it holds up!! Good luck
Years ago, I removed the oem valve and gave it a quick clean. Worked better but not 100%.
I found the identical valve in Stainless Steel. May have been EBay, but wound up getting two valves, brand new, stainless, forless than the cost of one oem checkvalve. So far so good. The task to replace it is pretty easy.
