accessory wire
Switched accessory wire ( and ground wire) is found in the left front portion of the Spyder. If you have a 12 volt accessory outlet option installed in the trunk, it is attached to that. Otherwise, it will be strapped to the frame behind the trunk in that area. I forget the color of the wires.
-Scotty
Just installed CB radio and XM satalite radio. There is only one accessory switch that works off the key. Its on the top of the fuse box purple and yellow wire. The Xm radio is 6 volt have to use a drop box tied it into accessories. :thumbup:
