krb1945
These symptoms seem to be pointing to a loose electrical plug in the lights circuit or a direct short to ground. Either fault would/can cause a fuse to blow and would be intermittent because of vibration and bumps. If I've read this correctly it started with a ABS fault and running light fuse blowing.
Also the engine shut down could be caused by the GPS.
A failing relay can also cause all the above symptoms. If you have a replacement set of relays install them and if the problem goes away then you know for sure. I had to replace all the relays at 1000 to 2000 miles because they kept shutting us down. We have had no such problems since replacing them.
The plugs may not have been plugged in tight after the deer accident.
I'm out of town right now and don't have my electrical schematics with me. Ken krb1945
