a question of light
russ russell
hi to everyone in the USA..im a newbie from the UK..i have recently bought a 2010rt limited addition and it appears that all the front lights do not come on when they are switched on.. I cant see a blown fuse , so have any of you folks got any idea whats wrong. im hoping you can throw some light on the situation for me..
best regards from across the pond:bowdown:
russ..
Welcome to the club
russ..
Hi Russ, I too have the same RT 2010 limited, and yes I'm on the same side of the Pond as you, do your front bottom lights come on when you start up? Always
The top lights are full beam and switch on in rotation with the bottom lights. any other combo means you have a fault,
Keep in touch it's a small band of us on this side;)
I have a 2012 rts check the relays in the front by switching them with the same relays that are in the front relay box the lights relay on the 2012 is the upper right in the relay box I ordered relays to have in stock
russ..
For the European version the lower projector lights, which are foglights in North America, are low beams. The upper lights, which are the headlights in NA. are high beams. They cannot both be lit at the same time.
