A LITTLE HELP PLEASE
BLACK SPYDERRT
i have 2011 rts, i already adjusted the front shocks. can the rear shock be adjusted the same way? and how do u get to it?? thx:helpsmilie:
The rear shock does not have a pre-load adjuster like the front. The RT model has an airbag, that is used for adjustment. On the base and A&C models, this is done by adding air at the Schrader valve under the seat. On the RTS and LTD, it is an automatic system. The setting is changed by adjusting the ride height using the switch on the switch panel near the glove box. If your RT won't hold air, check to see that the valve core is tight. If that doesn't cure it, see your dealer to find and repair any leaks in your system. If your 2011 RTS goes to a "Manual" warning instead of showing the ride firmness gauge, have your dealer perform Warranty Campaign 2011-6, and reset the ACS sensor limits.
