A few technical questions...
Never tried adjusting pressure on the fly, but otherwise it always worked
like advertised.
VSS light ? Never seen one, but generally my eyes are out of the cockpit
when I'm ryding, and in a corner? just saying....
Where in SoFlo is the corner?
As I said earlier, this isn't some special road or curve, I'm talking just making turns, any intersection although thinking it probably has been mostly rights - I'll have to push it on a left turn and see what happens. I can and will certainly work on my technique as I am a new rider, and I have only seen this when I started going faster making turns/around corners (not curves).
What's not clear to me is the guide (owners guide/manual but trying not to just call it the manual, lol) says under adjustment when riding that you will get the bar graph. On Page 145 it says "The manual message will appear onthe LH side of the digital display inplace of the bar graph indication toinform you that there is a problem withthe automatic suspension adjustment. " and show the image with word manual vertically in place of the bar graph but what is not clear is whether this is a problem if it comes up all the time, not just when I try to adjust it. But the bar graph is not normally there either. It seems there is a problem with it only when riding. Yes, it also says will self adjust but can stiffen/soften via the switch/bar graph.
Yea, me too but the flashing caught my eye, I had to look in the guide to see what the light even was - by location, didn't see it long enough to even make out the symbol clearly.
You have a problem with air system. Should have bar on left side of screen when adjusting while riding or anytime. I would lift seat & check the schrader valve for leaking. Then add some air. After doing that go for a ride & see if Manuel disappears from screen. Although it will probably return once you shut off.
I can/will do that but again to be clear the word manual doesn't stay on the screen. Only when you press the Hard/Soft ACS button once - the word Manual comes up instead of the bar graph.
Glad I have a STL. With out the PITA. Hope you fig problem & get to enjoy properly
Steve, my question was based on if the corner is local to me, we can see how another Spyder reacts. If you are nearby, come and compare your rear suspension adjust to ours. Also, if you need to compare before buying how BajaRon swaybar and FoxShox front end feels, swing by. That's what we ride and a short test ride may be possible.
PK
Oh, ok, thanks PK. I'm in NW Broward around 40-50 miles from RPB. Thanks for the offer, maybe we can hook up one day. I'll PM ya...
Steve
