998 spyder dipstck o ring in resivour
Ignore it - write that one off, leave it there, & go buy a new 'O' ring from your local motor parts store. :dontknow:
It's not likely to hurt anything lying around in the bottom of the oil header tank, & it's the wrong shape to end up getting sucked out of it too. The next time you need to remove the oil header tank for a service or any other reason, once it's off & empty, turn it upside down & shake until the 'O' ring comes out. :thumbup:
Curious. ....
Easiest is to remove the screen (large brass nut bottom rear of tank where the hose hooks up) get a worm drive hose clamp cause the okiter clamp is not reusable. Clean the screen while your there then snag the o ring. If you never cleaned the screen good reason to do it. But as mentioned you can get another one and forgrt it. :thumbup:
" O ' ring
I've been there - done that ( the cleaning ). I don't think you could get that " O " ring thru that hole without seriously damaging or breaking it...... and leaving it in tank isn't a problem ....IMHO ....Mike :thumbup:
:shocked::hun:HOW?!:dontknow: Mine sticks to top of dipstick EVERY time & I have to move it below threads before I put back in but it is always on the stick. I've read of people having them split & worried about doing myself but never one falling in nojoke
grabber tool
th
might try with a tool of this kind ? go slow and careful a little at a time going into the tank and out again ...
Gene,
Do you happen to recall the size of that big nut on the tank????
When you get a new O ring put a couple drops of super glue on it to secure it to the dipstick before you screw it in. I did that to mine a couple years ago and it stays put. Go easy on the super glue or you might not get your dipstick back out in one piece.
