shelbydave
Talk about raising the dead, almost exactly a one year old post raised from the dead.
I've tried them all and did not notice any difference in performance or mileage once the rotax had a few hundred miles on it.
JT
You'll probably see it again too... Actually, the octane rating is far less important than some other common mistakes people make...
1. No need to run a tank of premium to "clean her up". In fact, it probably does just the opposite, if you are regularly using a lower octane fuel. The burn inhibitors could tend to collect, whereas running the fuel you normally run, the engine / computer is tuned for that.
2. Stay away from ethanol if you possibly can - 10% would be the highest, and never 15%.
3. Avoid constantly changing brands of fuel. Pick one, and stay with it. While the formula is the same across the board, there are some brand specific additives that are used, and mixing those additives constantly can also leave deposits, or residue, as each additive alone may do wonders, when they are mixed, they may do harm. Try to stay with one brand, or use the "sister" brand if in a region where your brand isn't available (Exxon / Mobil for example). So that being said, you don't do yourself any favors by chasing the cheapest gas.
