59 Caddi Tailight install
RShrimp
picture.php
I was looking for a solution since I moved the tag I found that it blocked the stock tail lights. I found these on the net and just had to have them. These are LED versions and each one has 31 LEDs
picture.php
Now the thinking begins. Turns out they fit perfect in a piece of 3 inch PVC. Hmmmmmmmm
picture.php
I started making some PODS. The end result would be much shorter but you get the idea. I changed my mind as I did not want to drill a bunch of hole in the body to mount them.
picture.php
Rocket Launchers ???? Anyone?????
picture.php
I kepy looking at this spot which is part of the GIVI bag frames
picture.php
I decided to make a bracket to mount on the bag frames. No extra holes in the bike at all!
picture.php
The bracket test fitted (before paint)
picture.php
The end result. This is just the dim tail lights as I did not have a helper
picture.php
Side view. I left them upswept as everything on the back is upswept. I could have and still could bend the brackets to get them level.
I also added a flasher module that is adjustable and makes the brake lights flash a few times before going steady. This one alows you to adjust the flash rate and time delay. Pretty cool for less than $20.
So, Accoring to Dave the spyder had 240 LEDs on it when I bought it!
Now it has over 300!!!!!!!!!!
Looks good. I like to see mods that are one-off. Shows real imagination. Now for the caddy hood ornament:yikes::yikes:
