Lately my rydes have been 20 to 50 miles with temperatures of mid to upper 60's. I set my pressures at a tad under 20 PSI for front and under 28 PSI for rear tire. Yes, unfortunately I have Kenda tires.
I will be taking several 300 plus mile rydes with temperatures of low 50* F. Should I set the pressures at 18 and 26 PSI or even lower prior to the start of the ryde?
I wouldn't be using anything but maybe +/- 2psi from the OEM recommended pressure on Kendas!! :lecturef_smilie:
And while the 4psi rule (of thumb) is a good place to start for any other tire, there's also a well documented recommendation to
INCREASE your 'usual running' pressures (established/supported via the 4psi rule)
by about 2psi whenever you are planning longer, faster, &/or more heavily laden runs to avoid or at least minimise
any OVER-HEATING caused thru under-inflation! Your tire pressures are
MEANT to go up by about 4psi during a ride - any
less increase means you've
over-inflated them; any
more increase means you've
under-inflated them! :lecturef_smilie: But unless you are on a track and chasing the last bees-whisker of performance &/or tire life, you really shouldn't need to worry too much if they're within a psi or 2 either way... :thumbup:
So what everyone else has already said is up there ^^ is spot on,
don't overthink this;
- if you're not running Kendas, you really SHOULD NOT REDUCE PRESSURES for a longer, heavier than usual, &/or faster ride from your 4psi established/supported pressures; and
- if your Spyder is still fitted with Kendas, then DEFINITELY NO, DO NOT REDUCE YOUR PRESSURES FOR A LONGER, HEAVIER THAN USUAL, &/or FASTER RIDE than your usual ride.
For those sorta rides, if anything, you'd do the exact opposite to what you've proposed
up there, and (qualified a little depending on how cold it might get and your need for increased
wet road traction, but not snow & ice!
) you'd generally expect to
INCREASE your tire pressures by maybe as much as 2psi, but given the Kendas well recognised tendency to wear (the rears especially :sour: ) as if they're over-inflated anyway (altho they probably aren't, it's more likely just the centre of the tread been thrown out so that's the only bit that ever touches the road cos they are so lightly made, &/or the tire's too wide for the rim! :banghead: ) just use the OEM recommended pressures in your Kendas or you risk even more issues than usual!!
