mike3069
I've been getting a slight "pop" in my exhaust lately @ 3000 RPM under a slight load and decided since I have over 30,000 miles on the bike and haven't yet checked the valve clearance I would start the diagnosis by trying to rule them out. So I got my valves checked today @ Progressive Motorsports in Hudson Falls, NY.
Here's what they found:
Front cylinder
Intake .152mm
Exhaust .254mm
Rear Cylinder
Intake .152mm
Exhaust .279mm
The tolerances are:
Intake .110 to .180
Exhaust .220 to .290
No adjustments made. Cost 2.5 hrs labor $170.00 plus $2.50 Shop Supply fee. Total valve check with NO adjustment $172.50:clap:
I was so happy with this cost I bought a new helmet!
hyea:
It's not the valves, so when I got home I looked at my race flow intake and it needed a cleaning bad!
Now I will have to go for a ride in the morning to VT and see if that fixes the issue.
opcorn:If that doesn't do it I will try adjusting the juicebox next.
I'll keep ya updated.
UPDATE:
Seems that the dirty air filter was the culprit. I believe at low rpm (under 3000) the restricted flow was creating a rich enough condition that some raw fuel was getting into the pipe. When I opened the throttle to accelerate, it was igniting and creating the "pop" I was hearing. Just a theory.
Front cylinder
Intake .152mm
Exhaust .254mm
Rear Cylinder
Intake .152mm
Exhaust .279mm
The tolerances are:
Intake .110 to .180
UPDATE:
