mtdoragary
This is the max. I can move the left side.Throttle side,OK.Lots of cable for movement.The line from the reservoir is the problem.
I had the same problem. I had to disconnect the clutch hose from the cylinder and reroute it across the top of the engine to the left side of the main frame tube in order to get enough length. Mine's a 2008. I also had to take the left switch assembly wire OUT of the frame tube to get enough length. Of course all if this required removing the entire front cowl. But then again, I was adding 4" risers in addition to the factory 1" riser.
