3" riser from Spyder City
Zipper
I have the 1" BRP riser already installed. Will I be able to add the 3" riser from RT Sales Spyder City to it? Is there enough cable length to achieve this. Has anyone done this?:chat::helpsmilie:
Plenty have installed the NMN 3" risers with the BRP 1 " riser with no problems. Don't know anything about the Spyder City risers. :dontknow:
Should be plenty. I just had to barely pull on the cables to support the 3" SC riser without the BRP 1". Should be easy to get an extra 1".
You might want to wait until R/T has a fix for the steering lock...right now, if you get the riser, you will lose your steering lock function....some might not care, some might.
I park a lot on hills (for some odd reason), so a steering lock is important for me...
I only have the BRP 1" right now...
i do know with a 1 inch brp and NMN 3" they reach cut a couple zip tie's ,no problem.not familiar with the riser's your using
