210 miles @37.8 mpg.................
dave01
And that was following Doc today. I was surprised:yikes::yikes::yikes:.
Added the 2011 windshield and removed the lower winglets, tweaked the JB Pro a little and off we went today. Mostly highway, around 70-75 mph.
So far, my total average works out to 35.6 mpg over the last 2700+ miles.
What were you getting before you made the changes?
I gained a little over 2 mpg after the changes. Not a huge amount, but she is running great, no fuel fumes when running and still running at 4-5 bars today with 94 ( not correct) degrees on the air temp guage.
My Chinese calculator tells me that at 35.6 mpg and 6gal. of fuel would be
a total of 213.6 mi. with the engine running, Hope your going downhill..:pray:
Freebob...:doorag:
Your calculator did not take into consideration that he has a Fuel Safe auxiliary fuel cell in his front trunk. :D You should check out his mods thread, as it is very impressive. :thumbup:
Yep, 6 gal usable under the seat and 5 gal in the frunk. Yea I admit, I'm showing off. :D
I'm going to remember your mod in the G&G Rally...:shocked:
WOW
MY BAD....Guess your lights blinded me.....:lecturef_smilie:
Freebob..:doorag:
You sure that isnt Kilometers per gallon ? :roflblack:
Freebob..:doorag:
Sorry about that. I got a call from the International Space Station the other day asking me if I could tone things down a bit. I told them I would take it under consideration, but probably not. :roflblack:
You forgot to mention tha long cable attached to Doc's trailer hitch and your RT....
Hmmmm....
I think your calculator is busted...Or...you have had a miracle bestowed upon your Rotax....Or...maybe it was down hill the entire 2700 miles... ;)... Len
Nope. I have been diligent on checking this each time. RPM's kept at or below 5500, speed kept at no more than 70, unless passing or catching up to group. Its just a test to see how personal throttle control, use of the cruise and fuel mapping can change the mpg of the rotax.
Sounds like a kinda boring way to ryde.... but then you have another ride for excitement, dont you ?
