2025 Spyder Sea 2 Sky - Where is the Dedicated GPS Power Plug-in?
pvosbury49
I am in the process of buying a new (leftover) 2025 Spyder Sea 2 Sky Can Am. I lead a lot of rides for my group so I need a versatile and reliable GPS, and I don't want it to be dependent on my phone. I plan on buying a Garmin Zumo XT3 and mounting it in the center of the handlebars using a Lamonster mount. I have had many Garmin GPS units in the past and I am very familiar with creating rides using Garmin Basecamp.
Can anyone tell me where the dedicated GPS power plugin is located on the 2025 model of the Spyder S2S, and how difficult it is to gain access to it? I understand it has moved to different locations on different year models. Does anyone know if a video has been created showing what has to be removed to gain access to the plug-in?
Thanks in advance for any insight that can be provided.
I just bought an XT3, you use Tracker app now for that. Don't know if Basecamp would work on that, or probably much better functionality by using the newer Tracker app
I grabbed an Acrobat PDF copy of the 2025 Spyder RT Operator's Guide from this site:
On Page 34 it confirms that there is a USB port in the "glove box" in front of the handlebars, same as on my 2024 Spyder RT Sea2Sky.
I used a Garmin Zumo XT plugged into that port for power on my 2024 Spyder RT S2S before CAN-AM got the Apple CarPlay to work correctly.
Now that Apple CarPlay is working, that USB port is what I connect my iPhone too so that I have navigation on the Spyder's display.
Hopefully the plug you are looking for is still on the right side under a panel. There were some good videos of it on the Lamonster website.
This is an interesting question, whether the 2025 or 2026 has the accessory power port on the right side.
I have this docking station installed on my 2024 Spyder RT Sea2Sky:
It does connect to the accessory power port on the right front side of my Spyder.
You can see from the name that it says it fits Spyder RT 2020+, and on the webpage it shows 2020 thru 2026 Spyder RT/RT-L.
There's also a link to download the Installation Instructions, which show to remove the various panels to get to the power port.
Or just plug into the USB cable in the glove box.
I have a 2026 Sea to Sky. I bought a USB-A to USB-C adaptor and plugged that into the USB-A dongle in the glove box. I lifted the glove box out of the fairing, it's not fastened in place, it just sits there, and removed the little rubber bung in to bottom of it.
Then I fed a USB-C 3 foot cable under the handlebars and into the space where the glove box was. I reached down into the space where the glove box was and fished the cable out, passed it through where the rubber bung was and attached it to the USB-A to USB-C adapter.
The other end of the USB-C cable, which I had bought with a 90 degree connector goes to my phone or any other USB-C device.
I also bought a rubber seal item that attaches to the USB-C cable and covers the exposed USB-C connector to keep the moisture out when not in use.
The glove box just slots back into place.
This way I don't have to run a USB cable out under the glove box lid.
The USB-C cable I bought is plastic, not a woven finish, as I thought it would be more weather proof.
I got everything off Amazon.
JOMIHONEY Right Angle USB A Male to USB C Female Adapter, 90 Degree USB 3.0 to Type C Cable Connector Support Unidirectional Sides 10Gbps & Data Transfer, for Laptops/Phone/Tablet/PC
[5-Piece] Cozy USB Caps for USB C Cable - Tether/Cap Provides Dust and Oxidation Protection, Projection Adapter Cover, Protects During Travel, Portable, Designed by Cozy (Black)
Cable Matters 20Gbps Right Angle USB C Cable - 3ft, Supports Up to [8K@30Hz / 4K@120Hz Video, 240W Charging, 20Gbps Data Transfer] 90 Degree USB C Cable, Right-Angle USBC to USBC Cord
Right hand side behind the body panel just like on all 2020 to current RT. That connection is still available.
