bluewoo
Everything went great yesterday! I had about 625 miles once I returned from the dealership with a new engine and found a couple of panels not snapped in and luckily some members here pointed out a loose wire on the starter. I added the upper and lower adj air wings and make sure to add some lube to them as I could feel they didn't have anything lubricating the joint as you cannot do it after install. Very easy just time consuming because you have to pull the left and right upper panels - three push pins/three screws/pull and wiggle. I now have 853 miles and It was a very warm day down to Maryland for lunch and the spyder ran great!
