2021 F3 Ltd has awful Radio reception - where's the antenna plug?
Correction the washers helped the ground strap bolt but when I actually started it, it went to hell again, turns out the led lights are making radio noise.
I tried installing a longer antenna that helped some bought off ebay. After that I took the ground strap bolt and put two washers under it and that did the trick, my radio now plays like it should.
At the risk of redundancy, where is the offending ground strap located? I did pull the antenna leads apart and clean them (primarily located under the passenger seat on the Ltd) but the ground strap? No idea and I don't have access to a 'shop manual.' And oddly enough, I installed a shorter antenna and improved reception by a smidge.
