2020RT remaining gas in tank
BeRight
How accurate are: 1. The yellow semi-circle bar 2. Miles remaining indicator 3. Bike's MPG indication
MY RT after fill-up indicates 150 miles remaining
MY MPG average varies from 25-30 (mostly 25.5) - combo back roads and highway. On Highway traffic is moving at 75MPH+ (65 speed limit + legal 10 over) - so I go with the flow
I also find that when filling up and stopping when gas nozzle auto-shuts off that yellow semi-circle shows only approx. 7/8 full.
I don't care about gas mileage - what I am hoping is that I can trust the miles remaining countdown and whether it is OK to click the gas nozzle a couple times during fill up so that I can get longer range between fill-ups.
When my yellow semi-circle showed maybe 1/8 remaining I only put in 3.5 gallons at click off.
Thank u for your time.
Search engine leaves allot to be desired
I don't know about the 2020, but my wife's '17 RT-S will hold over a gallon more after the nozzle auto-stops. You have to pull the nozzle out a bit, because it is sticking quite far into the tank when fully-inserted.
We don't have "miles remaining" or "MPG indication" on her bike, so I have no idea how accurate they might be.
It's a good thing you are not concerned about MPG, because I think those numbers are HORRIBLE. In our limited time with the bike (5 months, about 4100 miles), we have found that MPG drops like a rock when speeds go over 65-70. We try to keep under 65 as much as possible, our average MPG so far is about 35.
Gas tank
You've been here since 2008 ..... The GAS tank fill level is the same as it was then ..... WHY.... because the gas nozzle goes directly into the tank .... where the it will be below the level of gas in the tank .... so it shuts off sooner than what is needed to fill the tank..... Even if you visually see the gas at the filler rim there will still be the Air Pocket for heat expansion..... I always fill to the rim ( visually ) .... and that means adding another 1.2-3 gallons after the AUTO Shut -off is triggered.... The KEY to accurate MPG's is, you must always fill the Tank to the same level..... Mike :thumbup:
I would like to make a suggestion:
The miles remaining and gauges are just representations of what is going on. Pretty to look at, but I am not going to base my ride on them.
Use one of your tripmeters...to keep track of total miles on the tank. Reset it to zero every time you refill the tank.
RE: filling. The auto shutoff is not where to stop on the fill. Pull the nozzel out to the ring and slowly decant more fuel. I usually get a gallon more. I fill slowly up to the ring, let it settle down and refill to the ring one more time. Then I am done with the fill.
When done, my gauge shows 270 miles to go. If you fill to the same level each time, you will also get a more accurate mpg number...if you keep track. I do, and get a consistant 40 mpg.
I can go over 200 miles before the tank light comes on. Since we consistantly do rides of over 100 miles. We usually top off the tank, before commencing a new ride. We would rather ride with a full tank, than one dangling around empty. Came close to running out once, and that was enough for me. On a long trip, in unfamiliar territory, we start looking for gas at a half tank. It is good to get off the bike and stretch every couple hours or so, IMO, of course.
No two machines are exactly alike do to the many variables. Get to know YOUR machine and act accordingly.
Hope you find this information helpful. :yes:
The hardest thing I find about attempting to consistently get the tank to the same fill level is the is the varying pressure of gas pumps and the unpredictability of so many nozzle valves. Makes one wish for a rotary hand crank pump with no nozzle valve at all.
I'll agree with that completely. Some pump nozzles don't react well at all to gentle squeezes. It's often a case of either off or full-on and what that usually means is another opportunity to clean up splash-overs. Commie pinko fuel nozzles!!:banghead:
With only 1500 miles on my 2020, I'm giving another couple thousand for break in to figure out my mpg, and then over several months period of time. Right now I'm looking at 35/36....
3000 miles and up before the fuel mileage starts to get where it should. 5000 is even better.
Thank you for the info so far
Two new things I will do, per suggestions: Set trip meter and put more gas in.
Per the display: 150 mile range and 25MPG just doesn't seem right even with only 300 miles to date.
On my 2008 RS and 2015 F3 MPG and range didn't vary significantly from day one. F3 always in mid 30's, ridden hard.
Well said Ark, will give it more time, more miles. By the way, had it out in a frog strangler today for about 3 hours, performed really well.
While I understand this thread relates to the 1330, on the off chance someone w/one of the twins is reading, the above doesn't apply to you. From the sticky "Do's and Do Nots" thread:
DO NOT Overfill the Gas Tank (Does not apply to 1330 models):
This causes a few problems. When you get an inch or more below the top of the tank, stop filling it – period!
Overfilling causes fuel to flow-over into the evap-canister or when the fuel gets hot and expands.
This can lead to problems with gas-fumes (smell), and a potential fire hazard.
In late 2012, early 2013, BRP sent owners of all models new gas-caps to seal better and help with the gas fume problem. However, the gas-fume smell can be persistent in some cases. See your dealer if you experience an excessive smell of fuel when riding or after. There are a few threads on the subject that you can thumb-through and share with your mechanic. http://www.spyderlovers.com/forums/s...-Fix-Gas-SMell
You don't even have the thing broke it yet!So fill it to the top and set your trip meter, you know what the tank will hold empty and go by that, then you can say at 180 miles I better find gas, or what ever,, Feel it out!!!
I use this pump to fill the spyder with non-ethynol gas that I have in 5 gal. cans for my generator. It guarantees a consistent fill every time.
The method I have described has never resulted in an overfilled fuel tank. Includes 6 spyders over 12 years and 175,000 Spyder miles. Also includes both engine styles. 4 998's and 2 1330's.
I went for a 195 mile zip through the twisties today. When I left the house I reset the A trip meter and when I got fuel (4 miles later), I reset the B trip meter. A for trip miles, B for fuel miles. At the end of the ride the gauge said 1/8 tank. Here's the fun part: The A meter said 37 mpg; The B meter said 22 mpg. They correctly said, A-195 miles and B-191 miles. Tell me what that means!
I take it you never ride any farther than about 100 miles from home?
Or do you carry that in your trailer when on a trip?
Thank you so much - this is one of the main reasons I started this thread (which I didn't properly explain) - to find out experiences 2020RT owners are having.
The bike's calculations seem bonkers. 2020 RT maybe has changes from previous years causing different results gauges/sensors/algorithms.
Hoping to gain others experience before going on a long journey and making way to many unplanned/ unnecessary gas stops.
I'll do your method on my next ride with A and B trip meters. I wonder in setting A/B would the status on left middle side of screen still show miles remaining before empty - I'll find out soon.
I've looked and looked at my 2020RT's display and can't find a 'miles remaining' display. Any chance for a picture or more words as to where?
Edit: I found it in the manual, but there is nothing displayed on my RT. ???
thumbnail.jpg it is the 154 mi so after filling tank until auto cut off this is range that it displays 154. When riding you'll see it count down in realtime 1 mile at a time.
View attachment 184781 it is the 154 mi so after filling tank until auto cut off this is range that it displays 154. When riding you'll see it count down in realtime 1 mile at a time.
You may see it count up, sometimes a bunch, if your riding changes from say 20 miles on the freeway to a steady 45 MPH down a country road.
