USAF
Ok. So, Gwen is back from the doctor's office. After few hours of surgery they believe they found and fixed the ailment.
I really hope this is the same issue that you all have experienced. The fix for Gwen is kind of comical. Ready for it.....?
Here goes.
The seat was plugged into the wrong connector on the harness. Which 1 you ask? It was plugged into the connector that is used for the passenger heated grips. :roflblack:
The connector for the seat was tied down and stuffed away. The connections were swapped and Voila! It worked LOL.
The surgeons initially tried a transplant with a known good seat, but discovered no heating after doing so. They also tested voltage and ohms. Everything checked out.
SO, I hope your issues are as simple as that. If you have the RT base and swapped for heated seats, make sure that the connections are plugged into 1 that may be hidden away. If you have an RTL, I guess the fix is technically the same. Except your passenger heated grips are probably plugged into the connector for the passenger seat and vice versa. So, just swap them.
I hope this helps and I hope this works for all of you :chat:
What was your initial problem ? Did yours not work at all or like everyone else where they only work for 5/10 min ?
