2020 RTL will not downshift nor shift into reverse! Ideas?!
You have probably just joined the waiting list for a new left hand control module. A search here will find a lot of owners are having that issue. BRP has changed the unit and they are caught up in the supply lines backup. Contact your dealer.
It will not downshift nor shift into reverse
I've been waiting since Oct for the left hand multi function switch to be released by BRP. That's for my 2018 RT Limited. Can't shift into Reverse, no manual down shift (down shifts automatically) and can't shift into Neutral without restarting the bike. It was a known issue by BRP on the 2018 F3's and RT's. Replacement is covered under my extended warranty, which is a blessing since without the warrant it would set me back about $954.00 parts/labor. My dealership is telling me July time frame now.
wondered what was going, Today I had to go into reverse then into 1st it would not go into 1 until I did
Did you have the brake depressed when you tried to go into 1st? You don't need to to go into reverse but you do to go into 1st, from either neutral or reverse.
