New guy here, had the Spyder 2 weeks and 600 fun miles. Checking the oil the other day the way the manual says to. Had it idling in neutral in my driveway for about 6 minutes and then the engine temp quickly moved to hot (very hot days here right now). Got the high temp warning and red indicator light. Temp on the digital readout showed 115 degrees, a 20 degree rise during idling. Radiator fans would never kick on idling in neutral. Shut it down, tried it again, same thing. Started it back up to pull in my garage, put it in first gear and the fans kicked on. So, I experimented some more with it idling for a few minutes in first gear, would start to heat up per the temp gauge and then the fans would come on (but always pushing air towards the rear at low speeds). So, my question is whether the fans are somehow programmed not to come on with the bike parked in neutral? Is all of this normal? I called my dealer and service guy "didn't know", said bring it in, might be a few days before he could look at it. Wanted to start here on this forum first. You guys seem to know the bikes well.
