NEXUS, like Copperman said, even tho you now have the paint code, which is a good start; buuuut....... if you
REALLY want your trailer's colour to 'match' that of your Spyder, I'd
STILL be going down the recommend path above - see the
Bold. :lecturef_smilie:
As soon as your Spyder came out of the paint booth at the factory, that paint colour started changing/fading as a result of everything it's been exposed to - so if you paint it
exactly as per the paint code now, it might be
reasonably close in colour, but it'll likely never '
match'! But if you simply use the paint code colour as a starting point and exactly colour match it via computer matching
NOW, your trailer will match the colour your Spyder is
NOW too, so it'll also continue to change/fade at much the same rate as your Spyder does as time goes on! So not only will it look closer if not exactly the same colour to start out with, it'll very likely stay looking the same colour from now on in too!
hyea:
Colour match by
ONLY using the paint code and,
at best you'll get a close approximation
NOW, only it'll then most likely fade/change differently to the (already somewhat changed) colour of your Spyder over time! :gaah:
Do you really need to ask me how I
know this happens?!? :banghead: And with darker, more intense colours (like Marsala Metallic!) this has
much greater impact than it does on lighter, less intense colours..... altho adding metallic or pearl can make them pretty difficult to match properly too! :sour:
So if you want to match the colour now and into the future, getting it done via the computer colour matching process is the way to go! :2thumbs:
