2020 RTL ACS Loses Air Overnight - is this normal?
chipveres
My 2020 RTL loses all air from the bag overnight, but the compressor puts it back in the morning. Is this considered normal?
UPDATE: With help from my wife and her stethoscope, we isolated the problem between the non-return valve and the elbow near it. Then we got rained out. More later.
FURTHER UPDATE: New elbow didn't do anything. By use of caps and plugs we were able to isolate the problem to the air bag or the line going to it. More parts ordered.
AND THE RESOLUTION: We had two leaks, one a cut in the air bag itself. The other was sneaky. The connection from the Schrader valve to the air block would leak, but only sometimes. Sometimes it was airtight and sometimes it would gush so badly you couldn't put air in the system even momentarily. I replaced the connector on the block end with one of the improved fittings from McMaster-Carr. Their part number 51875K61 for the straight male.
No, not normal. You have a pretty bad leak somewhere in the system. If you have an shop or other air compressor you can add air thru the schrader valve under the seat and use a soap solution to check for leaks. Do not exceed 90 PSI on the system. Best done when everything is cool, not after a ride. If you can't find a leak it's most likely the check valve on the compressor.
:agree: ....let me add, check the Schrader valve STEM it may be loose ..... good luck ....Mike :thumbup:
Is replacing a 2011 RT Air Bag substantially the same for a 2020 RT?
I see a video about replacing the air bag on a 2011 Spyder RT. But my Spyder is a 2020. Is the procedure substantially the same or profoundly different?
It's substantially the same. :thumbup:
There are no significant differences in the ACS itself, except that maybe your more recent model doesn't have a dash switch; but the major differences in the task will come back to tupperware removal, simply because there's been some changes there. :rolleyes:
