2020 rt limited brake pedal sticking
Mikey4201
BRAKELIGHTS WON'T GO OFF. affecting cruise control. asking what lube i could use to make the pedal release properly.
thanks for the help
thanks for the help
I like a dry LUBES like spray-on Silicone ..... It attracts less crude .... I would clean the whole area with something like Brake parts cleaner first, that also could loosen things up ..... Mike :thumbup:
Frist check if pulling up on the brake pedal turns off the brake light. If so on my 2014 I was able to shave down the rubber stop that the brake pedal rest against allowing the return spring to pull the lever up enough to keep the light off.
You could just have your dealer fix this under warranty.
