:yikes:
OK. Just had an issue with the VOLUME of my Garmin Zumo 590 through my Sena 20s. As I messed with my 20s, I found (on YouTube) how to pair my Moto G6 phone first, then the Zumo as a second "Audio Device". So I contacted Sena through the "chat" and the following is what I got ......
Chat started
Kevin joined the chat
Kevin
Hello, I am Kevin, how can I be of assistance for you today?
David
Sena 20s, Motorola Moto G6 and Garmin Zumo 590. I got the phone and the Zumo paired to the 20s just fine, HOWEVER, when the Zumo talks to the 20s, it's at FULL VOLUME! Even after I turn it down, it BLASTS back in at the next instruction. How do I set/control the start-up volumes on both the G6 and the Zumo?
Kevin
That should have resolved it. Since each feature has an independent volume control, if you lower down the volume by rotating the jog wheel counterclockwise while the instructions are on that should lessen the volume of the GPS.
Same goes for your phone when there is an incoming phone call you can rotate the wheel to adjust its volume.
Did you try to lower down the volume on the unit itself?
David
Well, ... It does NOT. Each time the Garmin speaks it BLASTS ME> There is NO seperate volume on the Garmin as it is designed for motorcycles and is controlled by the 20s.
Is ther a way to set a pre-adjusted volume on the 20s?
Kevin
I`m sorry but we have none, did you already update the firmware or perform any resets?
David
Most current on ALL devices.
Kevin
Thank you, then I guess there would be no other option left but to reset it. Have you performed any?
David
will try it later this evening ... Thanks ... Bye!
OK Then, I will have to look into this further. I had found out, as stated earlier in this post, that the Garmin Zumo 590 must be wired to OR bluetooth-ed (?) to a speaker of some sort. You cannot adjust the volume on the Zumo itself. It, somehow, must be adjusted through your phone (?) or somehow on the Sena, which their expert claimed he has no solution. I'll look further into this and post back, hopefully by this weekend.
