2018 vs 2019
I think the 2019 have 1 piece fenders and the reflectors are now stickers. You cannot put the led lights in them.
YES, the 2019 fenders are one piece. I've also heard that it's more difficult to add aftermarket lights to a 2019. More difficult to use plug-n-play feature.
Yes, I believe that is due to the 2019 internals been "upgraded" to the new interface BUDS2.
We will have Fender LED Lights for 2019's available sometime after the first of the year. They will be sequential and replace the reflectors. There is not a 2 pin connector under the A-Arms on the 2019 so will be using a harness to go up to the headlight assembly to break into the 2 pin connector up there for the running light portion. You would be tying into the turn signal wire by the mirror as normal for the sequential turn signal portion to work.
