I figured how to program the 12 channels on the radio:
How to set radio channels for 2018 Spyder
Start at Radio Screen
Press Jog dial IN for menu
Press Jog Dial DOWN to display configuration menu
Jog dial to RIGHT to FM
Jog dial to RIGHT opens AUDIO screen (station # on top, channel numbers on bottom, Jog dial pic on right)
Press hold jog dial IN a couple seconds, station frequency will be highlighted green
Jog dial RIGHT or LEFT to select desired station (hold to scan through faster)
Jog dial DOWN to select channel number
Jog dial RIGHT or LEFT to select desired channel number 1 to 12
Hold jog dial DOWN for a couple seconds to set the channel (green down arrow on Jog Dial pic)
Repeat for additional stations.
To get out:
Press Jog dial IN a couple times
Jog dial to the left a couple times to return to radio screen.
“IN” means to press the jog dial straight in
Remember, if you do auto select to set stations, it will erase all pre-set stations.
2018 Limited, Asphalt Grey Blacked Out.
