BertRemington
Fascinating. When I open the video it starts at the 4 minute mark. I never went to the beginning, just scrolled back far enough to see the side access. Before I saw the video I had tried to remove the speaker through the grill but no matter how I positioned it, it wouldn't fit through the opening. But then I'm not any good at puzzles either.
I had the Torx bit but not the mini-ratchet. However I found, using needle-nose pliers, if I turned the machine screw about 15 degrees I could use my fingers to finish the removal.
You really want to try the rear speaker housing separation method shown in video, which I couldn't get to work. You really don't want to remove the grills unless, like me, you have no other option. They are a pain to remove and almost impossible to install.
